Output Format
HyperMesh includes a template that allows you to output a HyperMesh ASCII database file. Entities in a HyperMesh database are output with this template without requiring further input from the user. When exporting using the hm/general template, HyperMesh always includes geometry data.
The following table
indicates the HyperMesh input translator and template for the
HMASCII finite element code.
| Finite Element Code | HyperMesh Input Translator | Template |
| HyperMesh ASCII | hmascii | hm/general |
