HMIN_readmodel()
Allows hminlib to read in all of the entities in the database.
void HMIN_readmodel(entityfunctionptr (* getfunction) (int function, HM_entitytype entities));
HyperMesh hminlib Function
- getfunction
- A pointer to the function that requests the functions that read each entity type.
- function
- The function to be performed.
- entities
- The entity type to be read in.
In order to not overwrite a particular element, call the
HMIN_overWriteEntity() function with flag = 0, and
after writing the element, set flag = 1 so that rest of the elements are
overwritten.
HMIN_overWriteEntity(HM_ENTITYTYPE_ELEMS, 0);
HMIN_element_writequad4(id, 0, nodes, collectorid);
Write all the attributes belonging to the element quad4
HMIN_overWriteEntity(HM_ENTITYTYPE_ELEMS, 1);Errors
None.
