Increment operator.
var_name ++
Operands
- var_name
- A scalar variable.
| Expression | Result |
a ++ , where a = 2 |
3 |
The increment operator increases the value of var_name by one. This operator is typically used in loop constructs.
The increment operator is not valid when used with curve-editing functions.
