hwf::setbackgroundcolor
Changes the background color for all windows in the session.
hwf::setbackgroundcolor color_rgb
Framework
Changes the background color for all windows in the session. The color change affects only the graphics area and it is not stored in the HyperMesh database file or the session file.
Input
- color_rgb
- The hexadecimal color value.
To set the background color to a dark color,
#242424:
hwf::setbackgroundcolor #242424Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.1
