hwI3DViewCtrl RotateDown
Rotates the model down about an axis oriented horizontally across the screen.
viewControl_handle RotateDown ?angle?
HyperView Tcl Modify
This command allows you to rotate the model down about an axis oriented horizontally across the screen. The rotation angle, in degrees, can be specified. If it is not specified, the default rotation angle set using the SetRotationAngle command is used.
- angle
- The rotation angle, in degrees.
To rotate the model down by 15
degrees:
hwi OpenStack;
variable t [expr rand()];
catch {
hwi GetSessionHandle sess$t;
sess$t GetProjectHandle proj$t;
proj$t GetPageHandle page$t [proj$t GetActivePage];
page$t GetWindowHandle win1$t 1;
page$t GetWindowHandle win2$t 2;
win1$t GetViewControlHandle vc1$t;
vc1$t RotateDown 15;
hwi CloseStack;Error
Returns HW_IllegalOp if the client window does not support this command.
