hwi GetSessionHandle
Gets a handle to the current session.
hwi GetSessionHandle sessionhandle
Tcl Query
This command retrieves a handle to the current session.
Note: An hwi instance is always
available.
- sessionhandle
- The user-defined name of the session handle that you want to create with this command.
To get a session handle with the name
"mySession":
hwi GetSessionHandle mySessionError
Returns the session handle name if successful; otherwise, an error message.
