hwIAVIExportOptions GetSize
Gets the relative size (in percent) used when exporting AVI files.
hwIAVIExportOptions_handle GetSize
Tcl Query
This parameter is used when exporting AVI files from either the video or animation clients during HTML export.
Returns the relative size (in percent) used when exporting AVI files. This is an integer value, with possible values including 100, 50, or 33.
To determine the current size used when exporting AVI
files:
mySessionName GetAVIExportOptionsHandle myAviOptions
myAviOptions GetSizeError
If an error occurs, this command returns 0.
