hwIJPGExportOptions SetQuality
Sets the quality used when exporting JPG files.
hwIJPGExportOptions_handle SetQuality quality
Tcl Modify
This parameter is used when exporting JPG files from any client during HTML export.
- quality
- The quality to be used when exporting JPG files. This must be between 0 and 100 (exclusive).
To set the current quality used when exporting JPG
files:
mySessionName GetJPGExportOptionsHandle myJpgOptions
myJpgOptions SetQuality 90Errors
Success (0) or an error code (see below).
- 3 = HW_InvalidHandle
- The handle used to invoke the method is no longer valid.
- 4 = HW_InvalidArgs
- The value of the argument quality is not in the range listed above.
