hwILayer SetVisibility
Sets the visibility of a layer.
hwILayer_handle SetVisibility new_state
Tcl Modify
When a layer is shown or hidden, all objects associated with that layer will also be shown or hidden. Currently, only curves, notes, and datum lines from the HyperGraph application are associated with layers.
- new_state
- "True"
- Shows the layer.
- "False"
- Hides the layer.
To hide a newly-added
layer:
hwi GetSessionHandle mySession
mySession GetProjectHandle myProject
set layerID [myProject AddLayer]
myProject GetLayerHandle myLayer $layerID
myLayer SetVisibility falseErrors
Success (0) or an error code.
- 3 = HW_InvalidHandle
- The handle used to invoke the method is no longer valid.
