hwIPage SwapWindows
Swaps the contents of two windows on a page.
hwIPage_handle SwapWindows window1, window2
Tcl Modify
- window1
- The index of one of the windows to be swapped.
- window2
- The index of the window to be swapped with window1.
Windows are numbered from left to right, and top to bottom, starting at 1.
To swap the contents of windows 1 and 2 on page
1:
mySessionName GetProjectHandle myProject
myProject GetPageHandle myPage 1
myPage SwapWindows 1 2 Error
Success (0) or an error code.
3 = HW_InvalidHandle - The handle used to invoke the method is no longer valid.
4 = HW_InvalidArgs - The value of the arguments window1 or window2 is invalid. These must both be greater than 0 and less than or equal to the number of windows on the page.
