plt3DIAxis SetMetaData
Associates a named meta-data value with the axis.
plt3DIAxis_handle SetMetaData name value
Tcl Modify
Metadata can be any string or string representation of a number.
- name
- The name of the value.
- value
- The value.
To set and get a meta-data value from a 3D
axis:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetAxisHandle myAxisName x
myAxisName SetMetaData species dog
myAxisName GetMetaData speciesErrors
None.
