plt3DIBarChart GetMetaData
Gets a named meta-data value previously associated with the chart.
plt3DIBarChart_handle GetMetaData
Tcl Query
Metadata can be any string or string representation of a number.
Returns a string (the meta-data value).
To set and get a meta-data value from a
chart:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetBarChartHandle myChartHandle 1
myChartHandle SetMetaData species dog
myChartHandle GetMetaData speciesErrors
Returns an empty string if the value is not defined.
