plt3DICursor Find
Moves the cursor to the point corresponding to an argument list.
plt3DICursor_handle Find args
Tcl Query
The argument string can contain X, Y, and Z values -or any subset. If you search for "y 7", you will get the first point in the row where y equals 7.
- args
- The argument string.
- which
- A string indicating which vector to get. The options include x, y, z, u, v, or w. X, Y, and Z vectors of a 3D surface and 3D line plot may be functions of U and V and/or X, Y, and Z. The W vector defines the contour.
To find the points closest to { 5, 7, 22
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetAxisHandle mySurfaceName 1
mySurfaceName GetCursorHandle myCursorName 1
myCursorName Find "x 5 y 7 z 22"Errors
None.
