plt3DICurve GetCurveGroupHandle
Gets the handle of the curves’ owner (a curve group).
plt3DICurve_handle GetCurveGroupHandle iCurve
Tcl Query
In the above example, the two curve group handles should point to the same object.
- iCurve
- The name of the new handle.
To get a curve group handle from a curve
handle:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName AddCurveGroup
myClientName GetCurveGroupHandle myGroupName 1
myGroupName AddCurve
myGroupName GetCurveHandle myCurveName 1
myCurveName GetCurveGroupHandle myGroupName2Errors
None.
