plt3DILegend SetHighlighted
Sets whether the legend is highlighted.
plt3DILegend_handle SetHighlighted enabled
Tcl Modify
The appearance of a highlighted legend will change to indicate that it is active or has been picked through the GUI. To see this effect, alter the highlighted flag to cause a redraw of the client.
- enabled
- Highlighted, either true or false.
To highlight the
legend:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetLegendHandle myLegendName
myLegendName SetHighlighted true
myClientName DrawErrors
None.
