pltICurve GetCurveInTipTail
Gets whether or not the curve is included in the calculation and drawing of the tip-to-tail curve.
pltICurve_ctrl GetCurveInTipTail
HyperGraph Polar Plot/Tip to Tail functionality.
Gets whether or not the curve is included in the calculation and drawing of the tip-to-tail curve. The return value is either true or false.
Returns false, which means this curve is not included in the calculation and drawing of the
tip-to-tail curve.
pltICurve_ctrl GetCurveInTipTail Errors
None.
