pltIDrawControl DrawFilledRectangle
Draws a filled rectangle.
pltIDrawControl_handle DrawFilledRectangle ulx, uly, lrx, lry, color
Tcl Modify
Returns 0 = HW_Success or 3 = HW_InvalidHandle.
- ulx
- X-coordinate of the rectangle’s upper left point.
- uly
- Y-coordinate of the rectangle’s upper left point.
- lrx
- X-coordinate of the rectangle’s lower right point.
- lry
- Y-coordinate of the rectangle’s lower right point.
- color
- The index of the color to be used (must be non-negative).
To draw a filled rectangle from (1, 4) to (5, 0) with a color index of
2:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName
myPageName GetWindowHandle myWindowName
myWindowName GetClientHandle myPlotName
myPlotName GetDrawControlHandle myDrawer
myDrawer DrawFilledRectangle 1 4 5 1 2Errors
None.
