pltIPlot GetTipToTailSelectionMethod
Gets the selection method for the tip-to-tail curve.
pltIPlot_ctrl GetTipToTailSelectionMethod
HyperGraph Polar Plot/Tip to Tail functionality.
This command gets the selection method for the tip-to-tail curve. Returns a string indicating the selection method. Options include “none”, “all”, “displayed”, and “selected”.
- None
- None of the vectors is selected. Manual selection is not allowed.
- All
- All vectors are selected. Manual selection is not allowed.
- Displayed
- Based only on the displayed vectors, you can select vectors manually.
- Selected
- Based on all the vectors of the plot, you make selections.
This command is only valid for polar plots, vector mode.
Returns “all”, which means that all the vectors are included in the calculation and drawing
of the tip-to-tail curve.
pltIPlot_ctrl GetTipToTailSelectionMethod allErrors
Returns an empty string.
