pltIVector SetValues
Sets the data values of the vector.
pltIVector_handle SetValues values
Tcl Modify
This method is only valid for value-based vectors.
- values
- A compound list of data values to be used by the vector.
To set the x and y values for curve 1, which as 11 data
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle plot_handle
plot_handle GetCurveHandle curve_handle 1
curve_handle GetVectorHandle x_vector_handle x
curve_handle GetVectorHandle y_vector_handle y
x_vector_handle SetValues "0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0"
y_vector_handle SetValues "1.0 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0.0"
hwi CloseStackErrors
Success or an error code.
