poIAdvancedQuery SetQuery
Sets the query string in the advanced query.
advancedQuery_handle SetQuery query
HyperView Tcl Modify
This command is used to set the query string in the advanced query.
- query
- Accepts only the following query strings: “entity.id”, “entity.pool”, “entity.value”, “entity.layer”, “component.id”, “component.name”, “subcase.id”, “subcase.label”, “simulation.id”, “simulation.label”, “elem.config” and “corner.data”.
To set the query string form the advanced
query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule extreme]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExtreme "TopN 3"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQueryRule "[rule_handle GetID]"
advancedQuery_handle SetQuery "entity.id entity.value"
hwi CloseStack
This command returns HW_Error, if an invalid string is passed to the query
string.
