poIAssembly SetIDVisibility
Sets the display state of the assembly ID (on or off).
assem_handle SetIDVisibility state
HyperView Tcl Modify
This command sets the display state of the assembly ID (on or off).
- state
- True or False.
To turn on the ID visibility of an assembly with an ID of
1:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetAssemblyHandle assem_handle 1
assem_handle SetIDVisibility true
hwi CloseStackError
Returns an non-zero value if an error occurs.
