poICFD GetMaxStepLength
Returns the maximum integration step length in the CFD Plot/Streamlines panel.
poICFD_handle GetMaxStepLength
HyperView Tcl Query
This command returns the maximum integration step length used in the process of the
streamline creation in the CFD Plot/Streamlines panel.
Note: The step length actually used
in the integration could be smaller than the value returned by this command.
To get the current maximum integration step
length:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetCFDCtrlHandle CFD_handle
hwi CloseStackError
This command always returns the current maximum integration step length.
