poICFD_rake GetNumberOfSeeds
Returns the number of the seeds in the rake used for the stream integration creation in the CFD Plot/Streamlines panel.
poICFD_rake_handle GetNumberOfSeeds
HyperView Tcl Query
This command returns the number of the seeds in the rake used for the streamline creation
Note: In the case of an "Area" rake, the number of seeds
returned could be smaller than the value specified by the
SetNumberOfSeeds command, since the real number of seeds cannot
exceed the number of elements in the 2D part, which is specified when the rake is
defined.
To get the number of the seeds in the rake used for the streamline
creation:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetCFDCtrlHandle CFD_handle
CFD_handle GetRakeHandle CFD_rake_handle [CFD_handle AddRake "line"]
hwi CloseStackError
Returns 0 if the core object associated with the rake handle no longer exists.
