poIFLDCtrl SetCategoryLabel
Sets the label of a particular band of the FLD zone category legend.
poIFLDCtrl SetCategoryLabel band_idx label
HyperView Tcl Modify
This command sets the label of a particular band of the FLD zone category legend.
- band_idx
- The index of the color band (valid values are 0,1,2,3,4,5).
- label
- The label for the particular band.
To set the 3rd band of the FLD zone legend to "My Custom Label":
Note: The example below
assumes that an FLD is currently plotted in a HyperView
session.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetFLDCtrlHandle fld_ctrl
fld_ctrl SetCategoryLabel 2 "My Custom Label"
fld_ctrl SetEnableState true
client_handle Draw
hwi CloseStackError
Returns a non-zero value if there is an error.
