poIIsoValueCtrl SetShowMidsideNodeResults
Sets the state of the "Show Midside Node Results" option for the iso control.
iso_handle SetShowMidsideNodeResults state
HyperView Tcl Modify
This command sets the state of the Show Midside Node Results option for the iso control.
- state
- Boolean value to set the "Show Midside Node Results" state to true or false.
To get the state of the "Show Midside Node Results" state in iso to
false:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetIsoValueCtrlHandle iso_handle
# Set the Show Mid-side Node Results to false so that midside node results are
# not computed and shown
iso_handle SetShowMidsideNodeResults false
hwi CloseStackErrors
Returns an error if the value state cannot be applied.
