poILayerFilter RemoveLayer
Removes the layer from the layer filter.
poILayerFilter_handle RemoveLayer layer_name
HyperView Tcl Modify
This command removes the layer from the layer filter.
- layer_name
- The name of the layer.
To create the layer filter, get the handle for the filter, and then remove the layer ("Ply
1") from the layer
filter:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle CreateLayerFilter 1 "Composite Stress" 2
result_handle GetLayerFilterHandle filter_handle 1
filter_handle AddLayer "Ply 1"
filter_handle RemoveLayer "Ply 1"
hwi CloseStackErrors
Returns an error if the layer filter controller handle is invalid.
