poIPostManager SetPoolAliases
Sets the pool aliases for pool reference resolution.
poIPostManager_handle SetPoolAliases entity_type list
HyperView Tcl Modify
This command sets the pool aliases for pool reference resolution.
- entity_type
- Possible entity types include: node, element, part, or system.
- list
- Represents a prioritized list of aliases.
To set the SetPoolAliases command for an
element:
{"shell;2d;membrane","solid;thick_shell;3d;brick","beam;line;1d","mass;0d"}
To set the SetPoolAliases command for a node:
{"node;part-1-1;global"} Errors
Returns 0 if successful, otherwise an error code.
