poIQueryDistanceRule GetStartAt
Gets the distance rule starting point from the advanced query.
rule_handle GetStartAt
HyperView Tcl Query
This command gets the starting point of the distance rule from the advanced query.
To get the starting point of the distance from the advanced
query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule mindist]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetDistance "50"
rule_handle SetStartAt Min
hwi CloseStack
This command returns empty, if SetStartAt is set to
invalid values.
