poISCL SetIntersectionTolerance
Sets the tolerance used while finding whether a path is intersecting a solid element.
poISCL_handle SetIntersectionTolerance tolerance
HyperView Tcl Modify
This command sets the tolerance used while finding whether a path is intersecting a solid
element.
Note: Change tolerance only if needed, as the results will
vary based on tolerance and setting larger tolerance may give incorrect results. Default
tolerance is 0.01f. Max is 0.5f.
- tolerance
- The tolerance used while finding whether a path is intersecting a solid element.
To set the tolerance used while finding whether a path is intersecting a solid element:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_ctrl
result_ctrl GetStressLinearizationCtrlHandle stresslin_ctrl
stresslin_ctrl GetSCLHandle scl_handle scl_id
scl SetIntersectionTolerance 0.02f
hwi CloseStack Errors
None.
