poISweepCtrl GetSelectionSetHandle
Gets the set handle from the axisymmetry controller.
poISweepCtrl_handle GetSelectionSetHandle handle
HyperView Tcl Query
This command returns the set handle from the axisymmetry controller. The handle can be used to query set information.
- handle
- The name of the handle.
To get the selection set handle from the axisymmetry
controller:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSweepCtrlHandle sweep_handle
sweep_handle GetSelectionSetHandle sset
hwi CloseStackErrors
Returns an empty string if an error occurs.
