poISymmetry GetOrder
Gets the order of symmetry operations.
sym_handle GetOrder
HyperView Tcl Query
This command returns the order of symmetry operations. See the list below for the meaning
of each return code:
- 0
- mirror, rect pattern, circ pattern
- 1
- mirror, circ pattern, rect pattern
- 2
- rect pattern, mirror, circ pattern
- 3
- rect pattern, circ pattern, mirror
- 4
- circ pattern, rect pattern, mirror
- 5
- circ pattern, mirror, rect pattern
To get the sequence of symmetry operations from the symmetry
control:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetSymmetryCtrlHandle sym_handle
set num [sym_handle GetOrder]
hwi CloseStackErrors
Returns an empty string if an error occurs.
