poISystem GetOrientation
Gets the orientation of the coordinate system.
system_handle GetOrientation
HyperView Tcl Query
This command returns the orientation of the coordinate system. The orientation string returned by this command contains nine values (three direction cosines are needed for defining each axes of the system).
To get the orientation of the coordinate
system:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetUserDefinedSystemHandle sys1 "UserSystem 2"
set orient [sys1 GetOrientation]
hwi CloseStackErrors
Returns a non-zero value if there is an error.
