poISystemCtrl SetSystemLabel
Sets the label of the system control.
sysctrl_handle SetSystemLabel label
HyperView Tcl Modify
This command sets the label of the system control handle. Typically this command is used to set a label for the system (for example: material, ply, elemental, etc.).
- label
- One character only.
To set the label of the system control to
"m":
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle res_handle
res_handle GetSystemCtrlHandle sys_ctrl_handle
sys_ctrl_handle SetSystemLabel "m"
hwi CloseStackErrors
Returns an error code of 3 or 4 if there is an error.
