poITextAttribute SetHeight
Sets the text height in pixels.
poITextAttribute_handle SetHeight value
HyperView Tcl Modify
This command sets the text height in pixels.
- value
- The height value to be set.
To set the height of the contour title to
25:
mySessionName GetProjectHandle myProjectName
set pageIndex [myProjectName GetActivePage]
myProjectName GetPageHandle myPageName $pageIndex
set windowIndex [myPageName GetActiveWindow]
myPageName GetWindowHandle myWindowName $windowIndex
myWindowName GetClientHandle myPostName
set modelIndex [myPostName GetActiveModel]
myPostName GetModelHandle myModelName $modelIndex
myModelName GetResultCtrlHandle myResultName
myResultName GetContourCtrlHandle myContourName
myContourName GetLegendHandle myLegendName
myLegendName GetTitleAttributeHandle myTitleName
myTitleName SetHeight 25Error
Returns 0 if successful, or an error code (HW_InvalidHandle) if the handle used to invoke the method is no longer valid.
