poITrackingSystem SetPlaneType
Sets the plane type for a tracking system.
tsys_handle SetPlaneType type_str
HyperView Tcl Modify
This command sets the plane type for a tracking system. This command should only be used for "plane" type tracking systems.
- type_str
- Any of the following three values are valid for this argument: OXY/OYZ/OZX.
To set the plane type of a tracking system whose ID is
2:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle 1;
model_handle GetTrackingSystemHandle tsys_handle 2
tsys_handle SetPlaneType OXY
hwi CloseStackErrors
Returns a non-zero value if there is an error.
