txtITextEditor GetEvaluated
Returns the evaluation state of text client text.
txtITextEditor_handle GetEvaluated
Tcl Query
The GetComplexAxis command returns the evaluation state of text client text, either true or false.
To add the text specified to the first window on the first page and retrieves the
evaluation
state:
hwi GetSessionHandle session
session GetProjectHandle proj
proj GetPageHandle page 1
page GetWindowHandle win 1
win SetClientType TextEditor
win GetClientHandle txt
txt SetRawText "{var = \"a Templex string\"} Let's display {var}"
txt GetEvaluatedError
If the datum in question is a horizontal datum line, valid return values are "phase" and "magnitude". If the datum line is vertical, there is an additional valid return value, "both".
The empty string is returned if there is an error.
Keywords
- complex plot
- complex datum
- associated axis
