Orient Bar2 Elements
Use the Stiffener Mesh: Orient tool to define bar2 orientation vectors or orientation nodes.
There are two kinds of orientation vectors: Global and Basic. Global is used for displacement systems (or analysis). Basic is the HyperMesh global system (where system ID = 0).
From the Marine ribbon, click the tool.
- Select elements to orient.
- Optional:
On the guide bar, click
to define orientation options.
To orient using a node:
- Uncheck the By Vector checkbox.
- Select a node.
To orient using a vector:
- Activate the By Vector checkbox.
- Use the options in the microdialog to orient.
Option Description Orient Beam/Bar as Plate Stiffener Click
to align the beam/bar
axis along the positive normal of an adjacent shell.Normals of adjacent shells are averaged since they do not have an angle greater than the threshold value (break angle) defined in the options. For sharp angles, the shell with the lowest ID is used as a reference. In the case of T-junctions, you can select a reference shell by hiding undesired shells and by setting the "Normal from shells" option to Displayed.
Rotate Elements Along the X-Axis
- orient 90 degrees
clockwise
- orient 90 degrees
counterclockwise
- dynamically rotate
using a manipualtorVector Tool and Systems Provide an arbitrary orientation vector in space using the Vector tool. - Click
. - Orient the vector then press Esc to return to the current tool.
- To select in which system the orientation vector component
is resolved, click
in the
Orient microdialog.- System - Select a pre-defined system using an entity selector.
- Basic System - Place all X, Y, and Z components in the output system of beam node A.
