Align to Planes
Use the Planes tool to project nodes, elements, lines and points onto a plane along a user-defined direction
From the secondary ribbon, click the Planes tool.
- Select nodes, elements, lines, or points as source entities to be projected onto the target plane.
- Use the Target selector on the guide bar to select between a plane or a direction.
Click
Figure 3.
