Run
Analyze the model and generate the results.
From the Analyse ribbon, Analysis tool group, click the Run
Solver tool, which runs the SEAM
code to analyze the model after it is generated.
From the guide bar, click
to select additional options.
Click
to display the Advanced Selection dialog. Select the required load steps.
You can select a single load step or multiple load steps simultaneously. Select
the necessary options and click Run.
- Generate excitation contributions
- Calculate excitation contributions.
- Calculate NCT effects
- Calculate NCT effects.
- Calculate Windowing effects
- Select the Block or
Unblock option for calculating the
windowing technique to be calculated.Note: This option is on by default.
- SEAM displays its progress. The display may close after the run is completed.
For the Windowing option, select the groups using the Regions options, which
need to be considered for windowing effects.
Note: The groups should have only SEA subsystems.
Contour tool to define the contour.
Figure 3.
- From the guide bar, select the type of contour to create by selecting Load Steps, Energy, and Frequency of Interest.
- From the guide bar, click = to select inplane or bending for plotting structural response.
- Click Contour.
Right-click on Subsystems Displayed to perform
visualization selections.
Figure 4. SEA Subsystem Contour
