SEA Junctions
A SEA junction is an energy flow path between two or more SEA subsystems corresponding to a single degree of freedom.
A connection defines how model elements are connected. Connections provide paths for vibration and acoustic power flow between elements and establish degrees-of-freedom at the element interfaces. A single connection contains one or more SEA junctions.
- Name
- Enter a unique name.
- ID
- Enter a unique ID.
- Connection Type/Config
- A predefined type which describes the general form of the connection. Select the connection type from the Config drop-down menu.
