Platform Support
Platforms, operating systems, and processors supported by Altair HyperWorks 2025 products, which includes 2025 solver packages.
Platforms Altair HyperWorks 2025
OS Version Architecture GUI Products Solvers
Windows 10 x86_64 YES YES
Windows 11 x86_64 YES YES
Linux RHEL / CIQ Rocky Linux 9.4 x86_64 YES YES
  • Windows Ultra High Definition (UHD/HiDPI) support requires Windows 10 Update 1709 or higher
  • RHEL= Red Hat Enterprise Linux
Linux
Altair HyperWorks products may install and run on other non-supported Linux distributions not mentioned or referred to in this documentation, but Altair does not test, certify, verify or warrant the reliability of the products on these platforms.
  • Altair™ products are tested on Gnome Desktop Manager (GDM)
  • Xen kernels are currently not supported kernels for Altair HyperWorks products
  • VirtualGL and other third-party remote visualization tools are not officially supported by Altair HyperWorks products
Ultra High Definition (UHD)
  • UHD resolution support (2160p) is only available for Windows 10 (1709 or higher).
    • Using Windows 200% scaling for 2160p is recommended.
  • Our recommended HD setting is 1080p for FHD and our Ultra HD setting is 2160p.
  • Java based tools within our products may still show some scaling issues under Ultra HD resolution.
Refer to the Hardware Recommendations and Certifications section for details.
Altair HyperWorks Products
  1. Altair® HyperMesh®
  2. Altair® HyperView®
  3. Altair® HyperGraph®
  4. Altair® MotionView®
  5. BatchMesher
  6. Altair® HyperLife®
  7. Altair® HyperMesh® CFD
  8. Altair® HyperMesh ® NVH
  9. Altair® HyperStudy®
  10. Altair® HyperView Player®
  11. Altair® SimLab®
  12. Altair SimSolid® (Windows only)
  13. Altair® Feko®
    • Altair® Feko® Applications
    • Altair® newFASANT™
    • Altair® WinProp™
  14. Altair® Flux®
  15. Altair® Solvers™
    • Altair® OptiStruct®
    • Altair® Radioss®
    • Altair® MotionSolve®
    • Altair® HyperXtrude®
    • Altair® Manufacturing Solver™
    • Altair® Multiscale Designer®
    • Altair® Seam®
    • Altair® HyperLife® Solver
  16. Altair® CFD Solvers™
    • Altair® AcuSolve®
    • Altair® ultraFluidX® (Linux only)
    • Altair® nanoFluidX®
  17. Altair® Twin Activate®
  18. Altair® Compose®
  19. Altair® EDEM™
  20. Altair® Inspire™
  21. Altair® Inspire Cast™ (Windows only)
  22. Altair® Inspire Extrude™ (Windows only)
    • Altair® Inspire™ Extrude Metal
    • Altair® Inspire™ Extrude Polymer
    • Altair® Inspire™ Friction Stir Welding
    • Altair® Inspire™ Resin Transfer Molding
  23. Altair® Inspire Form™ (Windows only)
  24. Altair® Inspire™ Mold (Windows only)
  25. Altair® Inspire™ PolyFoam (Windows only)
Platforms Added in Altair HyperWorks 2025
  1. RHEL / CIQ Rocky Linux 9.4
Platforms Dropped in Altair HyperWorks 2025
  1. SLES 15 SP3
  2. RHEL 8.4
Minimum Operating System Requirements
Table 1.
System/Hardware Information Linux Windows
Operating Systems
RHEL 9.4 (64-bit)
CIQ Rocky Linux (64-bit)
10 (64-bit)
11 (64-bit)
CPU AVX2 support AVX2 support
Memory 16 GB (higher recommended) 16 GB (higher recommended)
Complete Install Disk Space
~8 GB temporary disk space required for full Altair HyperWorks 2025 installation
Applications
72 GB
Help
12 GB
Applications
110 GB
Help
12 GB
Graphics Hardware 2 OpenGL 3D graphics accelerator compatible with OpenGL 3.3 or higher
Vulkan 1.2 or higher
OpenCL 2.1 required
True color (24-bit) support
Install/update to most recent OpenGL patches/drivers
1920x1080 screen resolution or higher for optimal user experience
4 GB or higher dedicated RAM
Only dedicated NVIDIA GPUs are supported (AMD, Intel® Arc™, and integrated onboard Intel chipsets are not supported)
OpenCL 2.1 required
Only dedicated AMD, Intel® Arc™, and NVIDIA GPUs are supported (integrated onboard Intel chipsets are not supported)
Linux System Requirements
Run the HyperWorks compatibility tool to validate your Linux compatibility with Altair HyperWorks products located under the <INSTALL_PATH>/altair/hwdesktop/utility/HWCompatibilityTool/ folder.
1 Local help installations may require modifying the browser to allow running active content from the hard disk. For search capability, the users should have a browser supporting either ActiveX (IE on Windows) or Java Environment plugin installed on their machine.
2 Altair HyperWorks Graphical User Interface (GUI) products, when used with Ultra High Definition (UHD) displays consisting of 1920x1200 or higher (for example, 3200x1800, 3840x2160 or 4096x2160), may result in graphical problems. Some GUI items may not be displayed correctly, some functionality such as image captures may not capture images correctly, and window selection may become an issue. Altair HyperWorks 2025 does not officially support these high screen resolutions. We suggest setting your resolution to 1920x1200 or lower to resolve or minimize these types of issues from occurring. Our development teams are aware of these problems and are working closely with the hardware vendors to find a quick resolution.
