AEFACT
Bulk Data Entry Defines real numbers for Aeroelastic Analysis.
| AEFACT | SID | D1 | D2 | D3 | D4 | D5 | D6 | D7 | |
| D8 | D9 |
| AEFACT | 5 | 1.2 | 0.2 | 1.0 |
| SID | Set identification number. No default (Integer > 0, should be unique) |
| Di | Real numbers. Default = blank (Real) |
- AEFACT entries should be selected by a CAERO1 entry.
- Embedded blank fields are not allowed.
- To specify division points, there should be one more division point than the number of divisions.
