Single File Input
Filename convention is ROOTNAME_0000.rad.
The file must start with:
#(blank) RADIOSSThe Engine options in the single file must be:
- Placed in the beginning of the single file
- Finish with /END/ENGINE
The Starter options must:
- Start with /BEGIN
- Finish with /END
Syntax has to be written
as:
#(blank) RADIOSS
Engine options
/END/ENGINE
/BEGIN
Starter options
/ENDComments
- Engine options must be in the main file, #include is not supported in the Engine file.
- In case of restart, it is sufficient to regenerate the Engine file alone.
- Multiple Engine instances are not supported in the Single File Input.
