Jump to main content
Radioss
Radioss
2025
Index
  1. Home
  2. Theory Manual
  3. Large Displacement Finite Element Analysis Theory Manual
  4. Interfaces
    Interfaces solve the contact and impact conditions between two parts of a model.
  5. Tied Interface (TYPE2)
  • Welcome
  • What's New
    View new features for Radioss 2025.
  • Overview
  • Tutorials
  • User Guide
  • Reference Guide
  • Example Guide
  • Verification Problems
  • Frequently Asked Questions
  • Theory Manual
    • Large Displacement Finite Element Analysis Theory Manual
      • Introduction
        Nonlinear finite element analyses confront users with many choices. An understanding of the fundamental concepts of nonlinear finite element analysis is necessary if you do not want to use the finite element program as a black box. The purpose of this manual is to describe the numerical methods included in Radioss.
      • Basic Equations
      • Finite Element Formulation
      • Dynamic Analysis
      • Element Library
        Radioss element library contains elements for one, two or three dimensional problems.
      • Kinematic Constraints
        Kinematic constraints are boundary conditions that are placed on nodal velocities. They are mutually exclusive for each degree of freedom (DOF), and there can only be one constraint per DOF.
      • Linear Stability
        The stability of solution concerns the evolution of a process subjected to small perturbations. A process is considered to be stable if small perturbations of initial data result in small changes in the solution. The theory of stability can be applied to a variety of computational problems.
      • Interfaces
        • Lagrange Multiplier Method
        • Penalty Method
        • Interface Overview
        • Tied Interface (TYPE2)
        • Auto Contacts
        • Solid and Shell Element Contact (TYPE3)
        • General Purpose Contact (TYPE5)
        • Rigid Body Contact (TYPE6)
          This interface is used to simulate impacts between two rigid bodies.
        • General Purpose Contact (TYPE7)
        • Ellipsoidal Surface to Node Contact (TYPE14)
        • Ellipsoidal Surface to Segment Contact (TYPE15)
        • Node to Curved Surface Contact (TYPE16)
        • General Surface to Surface Contact (TYPE17)
        • Common Problems
      • Material Laws
        A large variety of materials is used in the structural components and must be modeled in stress analysis problems. For any kind of these materials a range of constitutive laws is available to describe by a mathematical approach the behavior of the material.
      • Monitored Volume
        An airbag is defined as a monitored volume. A monitored volume is defined as having one or more 3 or 4 node shell property sets.
      • Static
        Explicit scheme is generally used for time integration in Radioss, in which velocities and displacements are obtained by direct integration of nodal accelerations.
      • Radioss Parallelization
        The performance criterion in the computation was always an essential point in the architectural conception of Radioss. At first, the program has been largely optimized for the vectored super-calculators like CRAY. Then, a first parallel version SMP made possible the exploration of shared memory on processors.
    • ALE, CFD and SPH Theory Manual
    • Appendix A: Basic Relations of Elasticity
  • User Subroutines
Refer to Kinematic Constraints for a detailed description.
© 2024 Altair Engineering, Inc. All Rights Reserved.
