Customize the Report Settings and Create a Report
Configure the settings and create an analysis report. You can save the settings so they can be used for quick reports.
First, run a structural analysis.
On the Structures ribbon, select Report Settings.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.The Report Settings dialog box is displayed. -
On the General tab:
On the Setup tab:
- Click the Parts button to select the part types you want to include in the report. Highlight each part type in turn to select the properties that you want to include in the report.
- Click the Connections button to select the connection types you want to include in the report. Highlight each connection type in turn to select the properties that you want to include in the report.
- Click the BCs button to select the boundary condition types that you want to include in the report. Highlight each boundary condition type in turn to select the properties you want to include in the report.
- Select the Include Images checkbox to include images of all selected items in the report.
On the Views tab:
On the Results tab:
- To restore the default or custom settings, click Restore and select the desired choice. By default, the report title is the model name; the description is left blank; and an image of the model in ISO view, the first load case, and the first result type are included in the report.
- Optional: To automatically open the report after creation, turn on Open Report.
- Optional: To save the current settings, which will be used for quick reports, click Save Settings.
- Click Create.
- Browse to the location where you want to save the file. The default location is C:\Documents\Altair\reports.
- Enter the file name.
- Optional:
Choose a file format:
- PPTX
- Click Save.
