Tutorial: Calibrator Analysis with Boundary Conditions
Tutorial Level: Beginner Model a calibrator using boundary conditions.
Open the Tutorial Model
Data files are available in the tutorial_models folder in the
installation directory in Program Files\Altair\2025\InspireExtrudePolymer2025\tutorial_models\extrudepolymer\tutorial-4\.
Open the L_profile.x_t tutorial model file from the file menu or by
dragging and dropping the file into the Inspire Extrude window.
Note: The imported model already has profile solid and calibrator dies created.
Set the display units to Metric (mm kg MPa C s).
Orient the Model
Click the Calibration ribbon.
Click the Orient icon.
On the model, click the exit surface of the profile solid.
Select Materials
Click the Materials icon.
Select Polymers > PP > PP_Generic.
Right click on the material and click Select.
After the material is selected, verify the bottom material under
Selected Materials and deselect the material that is
not needed for this analysis, PVC_Generic.
Note: To deselect a material, right click on the selected material and click
Deselect.
Specify Process Data: Inlet
Click the Inlet icon.
Select the profile inlet surface and edit inlet properties.
Right-click and mouse through the check mark to exit, or double-right-click.
Identify Calibrator Dies
This model has two calibrator dies. Select them one at a time and update the properties.
Click the Calibrator icon.
Select calibrator_die1 and edit die properties.
Repeat for calibrator_die2.
Identify Coolant Channels
Click the Coolant icon.
Coolant channels are automatically identified and highlighted in blue.
Submit the Job for Simulation
Click on the Analysis tool in the
Run group.
Specify the parameters of the analysis process. Select 3D
Mesh and Coarse mesh size.
Click Run.
View Simulation Results
When the analysis is complete, double-click the name of the run to review simulation results in the Analysis
Explorer.
Note: You can also open the L_profile.iep file to view the results.
