Automatically Create Hot Runner System
If your model geometry does not include a runner system, you can create a virtual hot runner system automatically with the Create Hot Runner tool.
Advanced ribbon, Runner System
secondary ribbon.
After you define the part cavity and ingates for your model, use the Create
Hot Runner tool to generate a runner system for the model including runners and
sprue.-
Click the Runner System icon.
Click the Create Hot Runner icon on the secondary
ribbon.
Inspire Mold automatically generates a hot runner system for your model.
Use the guidebar to select between an insulated or heated runner and set a
heated runner's temperature.
- (Optional) Select a runner system component to change its shape or dimensions.
