| Show/hide selected objects |
- Press H.
- Right-click the selection in the modeling window or Model Browser, and then
select Hide Selected from the context menu.
You can also show or hide objects by:
- Clicking their icons in the
Model Browser.
- Using the show and hide options in the right-click (context) menu.
- Using the Show/Hide Mode
tool in the view controls.
- Using the View menu.
| Isolate selected objects (parts, assemblies, sketches, faces, and reference
entities) |
- Press I.
select Isolate from the context menu.
- To isolate faces, in the view controls, select Show/Hide
Mode
, select Isolate
, and then select the desired faces.
Isolating an object zooms in and temporarily hides all other objects. |
| Show all/hide all objects |
- Press A.
- Right-click an object in the modeling window or Model Browser, and then select
Show All or Hide All from the
context menu.
- In the view controls, select Show/Hide Mode
. Then select Show All
or Hide All
| Reverse the selection |
- Press R.
select Reverse Selected from the context menu.
| Temporarily turn selected parts transparent |
Hold down Ctrl. |
