General
- Soldering Direction: Since the area of horizontal/vertical and front/end
side varies depending on the direction of soldering, setting the direction
of soldering is essential.
Figure 2. - Edit Component DB: You can create a new Component DB or read or modify the
Component DB file used in Text format (*.txt). When you click Edit
DB, the Component Group Manager dialog
opens.
- Section for list-up Component Group.
- Add: Can add new Component Group or select the saved Component Group.
- Can select component groups used in text format (*.txt).
- To the selected component group, you can add parts using the Naming, Filter, and Comment functions.
- Delete: Can delete Component Group.
- Naming: Classifies by name of Part, Reference, Footprint, and Package when generates Component Group.
- Filter: Classifies by naming string of Part, Reference, Footprint, and Package when generates Component Group.
- Comment: Classifies by comment of properties in Part, Reference, Footprint, and Package when generates Component Group.
- Save: Saves setting contents as file (design_name.pccls).
- Save as: Saves as file (*.pccls).
- Load: Loads the file (*.pccls).
- Layer Definition
Figure 7. Wording Summary of Soldering Pallets
