Naming
Classify components using the component name. Name matching components are added into the component database.
- Component Name Selection Filter: Set the filter type to be used to select components among part name, package name, footprint name or reference name.
- Add: Upon double-clicking the naming field, the tool shows the Select Component From List dialog. From the Not Selected list, select names on the list and add them into the selected component list.
Remove: After selecting components in the selected component list, click
Remove to remove the item from the list.
The removed item is moved to the Not Selected List.
